No power to start my Mahindra 6000 4WD
   / No power to start my Mahindra 6000 4WD #1
Oorah
Luther, Oklahoma
Mahindra 6000 '00' Series 4WD
Recently clearing woods and stopped for an hour break. When I came back there was no power to the switch. Gages are dead, no starter click even. I have looked for a few hours on the forum but no luck on finding a fix.
I replaced the starter relay switch no help there. Fuses seen ok.
any help appreciated.
   / No power to start my Mahindra 6000 4WD #2
Check to see if your PTO levers are disengaged.
   / No power to start my Mahindra 6000 4WD #3
PTO lever makes no difference on a 6000..its all mechanical..I'm just guessing here, but it may be a "fuse" or fusible link..I think there is one near the the switch...Did you get the care package with your 6000? (ie. the zip locked pack in your lower "glove box"...the "other" place you can stick the key in below the starter switch? BobG in VA
   / No power to start my Mahindra 6000 4WD #4
I believe, near the starter, you should find a pigtail with a fuse in it, that if blown it will enterupt power to the whole tractor.
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
TRUCKING INFO (A50775)
2025 Wolverine LHR-TWP80 Semi-Trash Water Pump (A50860)
2025 Wolverine...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
