No Power to fuse block 7010
   / No Power to fuse block 7010 #1
Keltic
Cape Breton Island
13 LS 7010C,91 Kubota L4150,Thomas 153S< Can Car C-4,BobCat 35E, BobCat 590,Pete 378 Tandem, Lots of other junk.
Hi, I suddenly lost power to the fuse panel that controls the heater, beacon, wipers etc, anyone know where to look first? Thanks, FMK
   / No Power to fuse block 7010 #2
Did you check the fuse box?
No power to the fuse box
   / No Power to fuse block 7010 #4
Just a guess, but there should be a fuseable link near the battery that feeds the fuse box.
Start at the battery and chase all of the positive side wires. There will be a large wire that runs to the starter, I’d bet there is another 10 gauge wire or wires continuing on to the cab area from the starter. Those should be fuse protected somehow.
Makes sense, thanks, I'll have a look!
   / No Power to fuse block 7010 #6
There are 2 60A slow burn fuses in the engine harness on the right side just above and behind the starter. If I remember correctly one of them supplies power to the cabin power relay that powers the fuse block for the lights, hvac, ect.
Thank you, just what I was looking for!!
Seems I have power, but no ground in the cab, is there a special ground between the cab and chassis?
   / No Power to fuse block 7010 #9
Did you ever find if there was a ground between cab and chassis?
2023 John Deere 333G for Parts (A56438)
2023 John Deere...
John Deere 4044M (A60462)
John Deere 4044M...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2011 John Deere 7330 (A59814)
2011 John Deere...
iDrive TDS-2010H...
CATERPILLAR PM622 COLD PLANER (A60429)
CATERPILLAR PM622...
