No power in hydraulic
   / No power in hydraulic #1
Genote2
Winnipeg mb
1965 Ford 5000
I have a 1965 Ford 5000 and do not have much power in lifting my round bale. Got a 727 loader fluid has been changed and level is good , read that possible plugged filter but can't seem to find one any body know where it might be manual is not helpful
   / No power in hydraulic #2
On our 1966 5000 an O-ring failed between the transmission housing and cover where the direction valves are mounted. This severly limited the flow and pressure available. The only filter on ours was an inlet screen on the pump that you accessed through an inspection / service hole on the right side of the transmission housing. Ours was a Select-O-Speed tranny so not 100% sure if the manual trannys were the same.
   / No power in hydraulic #3
Welcome to the forum.
:welcome:
I'm going to move this thread on over to the vintage Ford tractors section to see if anyone else has had a similar issue.
Mine is a select o matic as well
Thanks
   / No power in hydraulic #6
Thanks
selectomatic is an old juke box brand.
You have a Select - o speed transmission
   / No power in hydraulic #7
Guess I got them confused because we called it the Jerk-0-Matic :) cause it did
2000 Ford F-450 IMT Service Truck (A51692)
2000 Ford F-450...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2017 Ford Explorer SUV (A53117)
2017 Ford Explorer...
Chevrolet Tahoe SUV (A52377)
Chevrolet Tahoe...
2013 Nissan Juke SUV (A51694)
2013 Nissan Juke...
