No oil pressure
/ No oil pressure #1
willhoff
new concord, ohio
john deere
I have a JD 6405 with a SyncroPlus Transmission. The transmission had 75 psi of oil pressure which is low. I pulled the transmission. Everything looks good so I put a new pump, seals, O-ring in the unit and put it back together. I started the tractor everything worked good. I shut the engine off and topped the transmission oil off then started the tractor again. It wouldn't move. I have zero oil pressure. I pulled the transmission again and everything looks good. Any Suggestions??
/ No oil pressure
Air pocket in system (cavitation in pump?), any way to purge the pump and lines?
Dale
I didn't hear the pump cavitating when it was running and the pump was working for a time. The oil pressure check point is basically beside the pump so there is no oil lines to bleed. I wouldn't think air could be trapped in this system.
/ No oil pressure
Relief valve stuck open?
It looks like there is two valves that regulate the oil pressure in that transmission. It has a Pressure Regulating Valve and a Engagement Override Valve. I disassembled both valves. The spools where clean, no marks or scratches and they moved freely in their ports. The springs looked good and they measured the specified length. I don't have a way to test pounds of torsion on the springs but I was satisfied they are not at fault and put the valves back together.
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
Homemade Head Cart (A66408)
Homemade Head Cart...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
