No longer a regen virgin!
   / No longer a regen virgin! #31
Ok I need some education. How do you check the screen percentage. You mean a visual inspection or do you have some ECU funtion that tells you?
I think he's referring to the "dash" , should be some sort of gauge telling you the percentage before a regen.
   / No longer a regen virgin! #32
On My John Deere there is a digital information display that you can scroll through different information on the tractor like regen percentage, road spead, pto rpm, engine hours, pto hours, etc.
   / No longer a regen virgin! #33
On the Massey / Mitsubishi engine it has another rubber covered button right under the one that makes her get all hot and bothered. If you push it the number of bars shows how plugged up she is. Yours probably has something similar. Like I said , my plan now is to keep an eye on it and let her get her rocks off while in use rather than making me stand there and watch/wait.
So Loraine and I have done it a few more times now. Not as often as in the "honeymoon" period though.
Once, I even let her finish on her own and I went and got a sandwich!
I stopped putting DieselKleen in her fuel and I think that has increased our intervals. 27hrs, 49hrs, 95hrs, 130hrs 183hrs, 235hrs. So right about every 50hrs.
We are at 240 or so hrs now. With winter temps I now put Power Service Octane Boost in her fuel so we'll see what it does to her regen libido.
   / No longer a regen virgin! #35
Was it as good for her as it was for you? Did you nibble on her ears? Must treat her right don't you know :)
   / No longer a regen virgin! #36
I definitely treat her right. Lube at least every 10hrs! She put up with a lot in return.
Hey, to each his own. No shame.
Freighliner Tender Truck (A56436)
Freighliner Tender...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt GPI Pump (A59076)
LOT: Fuel Transfer...
2025 CFG Industrial Till Seed Drill Skid Steer Attachment (A56857)
2025 CFG...
2008 Ford F-150 Ext. Cab Pickup Truck (A56858)
2008 Ford F-150...
14' Avalanche Snowbox (A55272)
14' Avalanche...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
