No longer a regen virgin!
/ No longer a regen virgin!
I hate to bust your bubble but....
It does sound like it "wasn't her first time".:eek:
Ha! Some of y'alls responses are great! But this one might be the best so far.
Yes, I almost said she'd do it for anyone that rode her for long enough... But I dont really beleive that. :ashamed:
/ No longer a regen virgin! #23
WHAT ARE YOU GUY TALKING ABOUT ??? SOUNDS FUNNEY ANYWAY.
We are talking about EPA regulated diesel particulate emissions. What did YOU think we were talking about?!
/ No longer a regen virgin! #26
My Massey 1736 got her first regen around 50 and usually around 50 thereafter. It sounds to me like you got ya a "dirty girl" there old boy. What sorta brew are feedin her anyways, fuel oil?:stirthepot:
Interesting, How many hrs are other people going? Loraine has gotten in the mood at 27hrs and 49hrs. Feed her fresh diesel from the station with Diesel Kleen added. No oysters and champagne or anything!
/ No longer a regen virgin! #29
FWIW keep an eye on how much soot content you have there. Mine has Regened probably 3 or 4 times now but this time was different. For some reason it didn't kick off by itself until it was fully stuffed then that nasty horrid alarm decided to drive me nuts. No big thing usually but this was brush hogging the field and it became a major PITA.
Before it just did its thing quietly with the light on and running hotter than usual. This time even running the hog wasn't enough to shut the thing up. What it needed was to sit there and run it's program ( idling at 2000 RPM) for a half hour or more until it cleared it's throat. Why running it with the regen light lit hogging wouldn't do it I don't know. Anyways, lesson learned. From now on when I am doing something I am going to check the screen percentage and if it's over 75% I am going to kick it off manually and clear it while I am working so it doesn't have to sit there idling forever later on .
Ok I need some education. How do you check the screen percentage. You mean a visual inspection or do you have some ECU funtion that tells you?
/ No longer a regen virgin! #31
I think he's referring to the "dash" , should be some sort of gauge telling you the percentage before a regen.
/ No longer a regen virgin! #32
On My John Deere there is a digital information display that you can scroll through different information on the tractor like regen percentage, road spead, pto rpm, engine hours, pto hours, etc.
/ No longer a regen virgin! #33
On the Massey / Mitsubishi engine it has another rubber covered button right under the one that makes her get all hot and bothered. If you push it the number of bars shows how plugged up she is. Yours probably has something similar. Like I said , my plan now is to keep an eye on it and let her get her rocks off while in use rather than making me stand there and watch/wait.
So Loraine and I have done it a few more times now. Not as often as in the "honeymoon" period though.
Once, I even let her finish on her own and I went and got a sandwich!
I stopped putting DieselKleen in her fuel and I think that has increased our intervals. 27hrs, 49hrs, 95hrs, 130hrs 183hrs, 235hrs. So right about every 50hrs.
We are at 240 or so hrs now. With winter temps I now put Power Service Octane Boost in her fuel so we'll see what it does to her regen libido.
/ No longer a regen virgin! #35
Was it as good for her as it was for you? Did you nibble on her ears? Must treat her right don't you know :)
/ No longer a regen virgin! #36
I definitely treat her right. Lube at least every 10hrs! She put up with a lot in return.
Hey, to each his own. No shame.
