Loader No loader or 3point hydralics
/ No loader or 3point hydralics #1
relhogh
Florida
Yanmar 1500d
yanmar 1500D Green
After a major t.eardown of the rear axle and cleaing the hydralic filter I haven't goet any movement to the loader.
The fluid is up to the full line.
Do I need to overfill to get the screen(filter) covered?
/ No loader or 3point hydralics #2
The screen should be covered already if you filled it. Is it between the marks on the dipstick? How was the screen? How much fluid did you put in? Did you install it open end to the right side?
/ No loader or 3point hydralics #3
If your answers are all good to the above questions you might try cracking open the discharge line a tad. The pump may be air locked. Don't get carried away or you might get an oil bath.
Hey "D"
Yes to all. put in a little over 2 gallons.
Winston1,
Where do I crack open the line??:confused3:
Will check it out.
Winston1
You hit a home run.
I turned the nut 1/4 turn and cranked up the tractor.
I heard a pop and tightened the nut.
Hydralic oil was everywhere.
The bucket and 3point work fine(without a load).
I lost about a quart of oil and made a jolly mess.
Thanks again
:):thumbsup:
:) Thanks to everyone for helping with my brake job and hydralics.
I really did appreciate all the help.
I am including a few pictures. I did not take many on the buildup. some may be the same.
You guys are good.
PS YOU MUST GET IN THE CASE TO REMOVE AXLE AND BRAKES
1350-gallon Liquid Tender / Nurse Trailer (A66285)
1350-gallon Liquid...
2 Row Cultivator (A64047)
2 Row Cultivator...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2017 FREIGHTLINER M2 WATER TRUCK (A65643)
2017 FREIGHTLINER...
2019 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2019 ROCK SOLID...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
