Loader No loader or 3point hydralics
/ No loader or 3point hydralics #1
relhogh
Florida
Yanmar 1500d
yanmar 1500D Green
After a major t.eardown of the rear axle and cleaing the hydralic filter I haven't goet any movement to the loader.
The fluid is up to the full line.
Do I need to overfill to get the screen(filter) covered?
/ No loader or 3point hydralics #2
The screen should be covered already if you filled it. Is it between the marks on the dipstick? How was the screen? How much fluid did you put in? Did you install it open end to the right side?
/ No loader or 3point hydralics #3
If your answers are all good to the above questions you might try cracking open the discharge line a tad. The pump may be air locked. Don't get carried away or you might get an oil bath.
Hey "D"
Yes to all. put in a little over 2 gallons.
Winston1,
Where do I crack open the line??:confused3:
Will check it out.
Winston1
You hit a home run.
I turned the nut 1/4 turn and cranked up the tractor.
I heard a pop and tightened the nut.
Hydralic oil was everywhere.
The bucket and 3point work fine(without a load).
I lost about a quart of oil and made a jolly mess.
Thanks again
:):thumbsup:
:) Thanks to everyone for helping with my brake job and hydralics.
I really did appreciate all the help.
I am including a few pictures. I did not take many on the buildup. some may be the same.
You guys are good.
PS YOU MUST GET IN THE CASE TO REMOVE AXLE AND BRAKES
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
2001 Club Car Carryall 6 Medical Utility Cart (A64553)
2001 Club Car...
27x32 CIH Rim (A65640)
Airco AC/DC Welder Generator (A66408)
Airco AC/DC Welder...
2017 Hyundai Sonata Sedan (A64557)
2017 Hyundai...
