No hydraulics
/ No hydraulics #1
Phil in ND
Arnegard, ND
Kubota / M7040 and B2910
I have a Kubota M7040 with hydraulic shuttle shift, rear blade on three point and factory loader. I plugged the tractor in to warm the engine. Started the engine, let it idle for twenty minutes, went to raise the rear blade, nothing, tried the loader with the same results, tried the shuttle shift and nothing happened. Tractor has 240 hrs full of hydraulic oil. Temperature was at 0 degrees. It worked fine when I parked it about a week ago. Any ideas?
/ No hydraulics #2
just a wild guess...frozen moisture somewhere in the system...
/ No hydraulics
Well I don't know if it was moisture or to cold to work, but I put a space heater under it for a couple of hours and it worked fine. Thank you /pine!
/ No hydraulics #4
Oil moves slow at low temps, but it will flow. If nothing is moving, something froze, which means water. I'd get excited about finding & removing the water before it freezes somewhere it breaks something.
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A69167)
2006 CHEVROLET...
Unused 2023 Cross Tech Brushwolf Alpha XP 74in. Brush Cutter Skid Steer Attachment (A66734)
Unused 2023 Cross...
