No heat in cab
/ No heat in cab #1
fruitcakesa
CavendishVT
M6040 JD 450C
Is there any one familiar with the under seat climate control on the M6040. the heat stopped blowing hot air and only blows cold. I’m guessing that the heater control valve has failed closed. A few years ago it stuck open and I put a manual ball valve on one of the heater water lines so I could turn it off in the warm weather. This is the opposite. It does still have AC though not very cold.
Where is the valve located and is it fixable or replaceable
Any help would be appreciate
/ No heat in cab #2
Open the ball valve that you installed when the original control failed. You should have heat. If you don't, then it might be low on coolant, or the heater core could be air-bound and not allowing the coolant to flow through it. If that is the case, then check with your dealer service department and ask how to remedy the problem. The process to remove the air sometimes is easy and other times it is difficult.
/ No heat in cab
Ball valve has been open and coolant level is good, so checking airbound is next. Thanks for the info.
/ No heat in cab
I pulled the seat out to access the heater control lever and was able to get it off the electric control unit. Then with a good stout push was able to move it to the open position. I thought I was home free but not to be still blowing cold. Temperature gauge Is at normal temperature and the rad hose is warm but I can’t locate the WP hoses to check them. I will try looking again tomorrow when it warms up. Oh yes, coolant level is about 2 inches up in the bottle.
/ No heat in cab #5
Unless the bottle is part of the pressurized system which it’s usually not on Kubotas it’s level doesn’t mean anything. You have to open the radiator cap and check the coolant that way. My Kubota skid steer and GM suburban both lost heater function when the coolant got slightly low.
/ No heat in cab
Thanks for that information. I will check it out tomorrow. I hope I can track this down before the really cold temperatures are here.
/ No heat in cab
Well coolant level is right to the top of the filler neck😩 I’m am about done.
/ No heat in cab #8
My Chevy Silverado had the same issue.
There was a clog in a weird location, where the coolant returned from the heater,,
I ended up finding the clog by pressurizing the coolant line going into the heater core
I used air pressure.
It fixed it,, I drove the 1999 truck today, it was cold this morning,, the truck heater was HOT!!
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
2020 BOBCAT E55 EXCAVATOR (A59823)
2020 BOBCAT E55...
John Deere S350 (A60462)
John Deere S350...
PRO SERIES SPRING SWAY BAR HITCH (A60430)
PRO SERIES SPRING...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
