Oil & Fuel No fuel to filter
   / No fuel to filter #1
Jeff Saunders
Hot springs, Ar.
Kubota M7060
I changed fuel filter on my 5010 hydrastat mahindra now the bowl will not fill with fuel. I think it has electric fuel pump. Could it be bad ?
   / No fuel to filter #2
Sounds like you didn’t Prime it. Fill the bowl with fuel manually.
   / No fuel to filter #6
Well, at least you've proved that the fuel delivery system works between the fuel bowl - fuel filter - injectors - engine.
All that's left is from the fuel tank to the fuel bowl. Some sort of blockage... a kink in the fuel line or debris at the bottom of the tank.
If you were to remove the fuel line from where it attaches to the fuel bowl, does fuel flow freely out of the line?
   / No fuel to filter
I did and there was no fuel flow out of line. I even ran a wire in it until it reached the pump. Shouldn’t the electric pump pump fuel to filter bowl when key is on ? The filter is above the tank so it’s not going to gravity feed
   / No fuel to filter #8
On my 4105, fuel from the tank to the fuel-bowl is gravity fed. From there, the fuel pump draws the fuel through the filter and then sends it to the injectors.
Can you put an 'inspection camera' down into the fuel tank an have a look around?
   / No fuel to filter
No I can’t Don’t have access to one. Was running fine till I changed filter.
   / No fuel to filter #10
Maybe the missing link question......did you change the filter and then it stopped working OR did it stop working and the first thing you tried was a new filter?
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
LED Peterbilt Sign (A50324)
LED Peterbilt Sign...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
