No Front Axle Fluid
   / No Front Axle Fluid #11
...i read an older thread a while back about the front case axle oil always needing more after delivery. well, same as jerky discovered...not even registered on the stick. however, i could see the fluid down in the bottom...so it's not dry but definitely very low....
Same happened to me. When I bought my 2660, the salesman went over all of the key points with me. He pulled the front axle plug, showed me how to check the fluid, etc. So I know it was full when I bought it.
After reading here that bx's often will have low oil in the front after using it a while I went and checked. Sure enough it was low. did not even show on the stick.
Thanks to the folks here for the heads up. I check it often and it has never been low again.
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Landoll 7130 Harrow (A59814)
Landoll 7130...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
