No forward with HST pedal
   / No forward with HST pedal #1
dlc49
Wolcott, NY
LS R4041H
While traveling on the road I turned off cruise and pedal didn't return, finally used reverse pedal to get stopped. Forward just rests on the floor but can [pull up on the reverse to move forward. If I pull up on forward it does pull the reverse pedal down. Any ideas?
   / No forward with HST pedal #2
Crawl under there and look for a pin possibly missing. That happened to me on my first tractor. I put one of those circular key retainers back in place of the pin.
Ralph
   / No forward with HST pedal #3
I think Ralph is on the right track. Sounds like using cruise control allowed slack in the linkage and let a pin to fall out.
Spring pin appears to be intact. When I pull up on the pedal it does pull the reverse down.
Turned out to be the spring pin was in 3 pieces and had enough of a spur to catch when pulling up! Thanks for your response.
   / No forward with HST pedal #6
Thanks for posting the fix.
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2019 International Bucket Truck (A55973)
2019 International...
