No forward with HST pedal
   / No forward with HST pedal #1
dlc49
Wolcott, NY
LS R4041H
While traveling on the road I turned off cruise and pedal didn't return, finally used reverse pedal to get stopped. Forward just rests on the floor but can [pull up on the reverse to move forward. If I pull up on forward it does pull the reverse pedal down. Any ideas?
   / No forward with HST pedal #2
Crawl under there and look for a pin possibly missing. That happened to me on my first tractor. I put one of those circular key retainers back in place of the pin.
Ralph
   / No forward with HST pedal #3
I think Ralph is on the right track. Sounds like using cruise control allowed slack in the linkage and let a pin to fall out.
Spring pin appears to be intact. When I pull up on the pedal it does pull the reverse down.
Turned out to be the spring pin was in 3 pieces and had enough of a spur to catch when pulling up! Thanks for your response.
   / No forward with HST pedal #6
Thanks for posting the fix.
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51243)
UNUSED INDUSTRIAS...
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
CATERPILLAR 740B OFFROAD DUMP TRUCK (A51242)
CATERPILLAR 740B...
PALLET OF MISC LINCOLN ARC WELDER, AIR COMPRESSOR (A51244)
PALLET OF MISC...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2006 Ford F150 (A50323)
2006 Ford F150...
