No fire on left cylinder with John Deere 425
   / No fire on left cylinder with John Deere 425 #1
Rob50056
Springfield,Mo
John Deere lx288 and 425
My 425 isn't getting any spark on left cylinder.
I switched coils and spark plugs and still no spark on left cylinder.
Right cylinder fires with either coil or spark plugs.
Any suggestions what to check next?
   / No fire on left cylinder with John Deere 425 #2
Bad spark plug wire?
   / No fire on left cylinder with John Deere 425 #3
Check left side ignition trigger, as sated by K7LN
Clean and reseat any connectors in the ignition circuit.
This engine has two pulser coils mounted near the flywheel.
Swap them and see what happens.
I swapped pulser coils and still only fire on left side.I lightly sanded contacted,tested connections on each side of plugs and they are continous.
I measured resistance as in Manuel and both passed.
What does this suggest?
   / No fire on left cylinder with John Deere 425 #5
Rob,
It would be best if you would have just one thread on your issue.
I suggest that you contact the moderator and ask him/her to combine you post.
Richard
New/Unused 7ft 8 Drawers and 8 Cabinets Workbench (A51573)
New/Unused 7ft 8...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
1999 Ford Ranger Pickup Truck, VIN # 1FTZR15X6XTA79787 (A51572)
1999 Ford Ranger...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
