No fire on left cylinder with John Deere 425
   / No fire on left cylinder with John Deere 425 #1
Rob50056
Springfield,Mo
John Deere lx288 and 425
My 425 isn't getting any spark on left cylinder.
I switched coils and spark plugs and still no spark on left cylinder.
Right cylinder fires with either coil or spark plugs.
Any suggestions what to check next?
   / No fire on left cylinder with John Deere 425 #2
Bad spark plug wire?
   / No fire on left cylinder with John Deere 425 #3
Check left side ignition trigger, as sated by K7LN
Clean and reseat any connectors in the ignition circuit.
This engine has two pulser coils mounted near the flywheel.
Swap them and see what happens.
I swapped pulser coils and still only fire on left side.I lightly sanded contacted,tested connections on each side of plugs and they are continous.
I measured resistance as in Manuel and both passed.
What does this suggest?
   / No fire on left cylinder with John Deere 425 #5
Rob,
It would be best if you would have just one thread on your issue.
I suggest that you contact the moderator and ask him/her to combine you post.
Richard
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
2015 KOMATSU PC35 MR-3 EXCAVATOR (A51246)
2015 KOMATSU PC35...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
2010 L3 MEP-806B GENERATOR (A52576)
2010 L3 MEP-806B...
