No fire on left cylinder with John Deere 425
   / No fire on left cylinder with John Deere 425 #1
Rob50056
Bronze Member
Springfield,Mo
John Deere lx288 and 425
My 425 isn't getting any spark on left cylinder.
I switched coils and spark plugs and still no spark on left cylinder.
Right cylinder fires with either coil or spark plugs.
Any suggestions what to check next?
   / No fire on left cylinder with John Deere 425 #2
Bad spark plug wire?
   / No fire on left cylinder with John Deere 425 #3
Check left side ignition trigger, as sated by K7LN
Clean and reseat any connectors in the ignition circuit.
This engine has two pulser coils mounted near the flywheel.
Swap them and see what happens.
I swapped pulser coils and still only fire on left side.I lightly sanded contacted,tested connections on each side of plugs and they are continous.
I measured resistance as in Manuel and both passed.
What does this suggest?
   / No fire on left cylinder with John Deere 425 #5
Rob,
It would be best if you would have just one thread on your issue.
I suggest that you contact the moderator and ask him/her to combine you post.
Richard
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53472)
2017 Yale GLC050VX...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
