No Filters at NAPA for CK30
   / No Filters at NAPA for CK30 #1
ulflyer
lexington nc
CK 30H
Stopped by yesterday and they had very listings for KIOTI. Only an oil filter for the CK20 & 35. Zero for the CK30. :( If Napa doesn't have anything, then no one else is likely to either. I like to change oil more frequent than the book calls for. My old 24 YO Massy Ferg 3 cyl Japanese made tractor had about half doz or more aftermarket filters avail. Oh well........:p
   / No Filters at NAPA for CK30 #2
Somebody isn't trying very hard.
Strange NAPA didn't have it because it is merely a rebranded Wix. Wix shows they have your filter. Just looked it up on Wix.com. Easy. You can even find a store near you with their dealer finder.
http://www.wixfilters.com/filterloo...9&TempSubMake=651&TempModel=41501&TempEngine=
Not so sure the fella knew how to read his book very well.
   / No Filters at NAPA for CK30 #3
How about just purchasing kioti brand from a dealer??
Never hurts to support the brand right?
Joel
   / No Filters at NAPA for CK30 #4
I do belive the CK25,30 and 35 are the exact same engine other than displacement. So all the filters would be the same.
   / No Filters at NAPA for CK30 #5
I agree with JoalD. Buy your filters from your dealer. When I go in I get one Tranny filter and 4 oil filters, I change the filter with every oil change, and the tranny filter at the recommended 400 hours. I leave with around $10 left from a $50 bill. Oil filters are around $6 each. Pretty cheap if it helps the dealer stay in business so it's easier to get other parts when I need them.
   / No Filters at NAPA for CK30 #6
They may not stock it but the 1324 is correct. I walked into a NAPA and asked for a 1324 and 1347 they had neither. I was able to buy both at carquest. From Carquest its 85324 for the exact same filter. A different NAPA stocks both filters I just referenced as does my local Carquest.
   / No Filters at NAPA for CK30 #7
Just checked the Napa number for the engine oil filter number that I bought about a month ago. It is 1324. My closest dealer is over 2 hour drive away. Having said that I have ordered a set of hydraulic filters for my CK35 HST from my dealer in Oregon. :thumbsup:
If you can, as other posters have suggested, support your dealer. :)
   / No Filters at NAPA for CK30 #8
My Kioti, my wife's Tuscon, and my daughter's Elantra all use that 1324 filter. That makes it nice and easy on me to stock filters. :)
   / No Filters at NAPA for CK30 #9
The 1324 fit both cars that is awesome:thumbsup: I test fit one on my Rio with no luck. There was interference with the alternator bracket before the the filter was seated. So I will stick with the 1347/EAO36 filters, only slightly less capacity then a 1324.
Do not use a 1347 in place of a 1324 on your tractor. The 1324 has a bypass pressure roughly double that of the 1347 so the 1347 will go into bypass far sooner if used on a diesel.
Thanks guys for the feedback. When I got the CK30 I figured there would be lots of info on alternate filters. I always make a list of all brands that fit whatever vehicle I own; just something I like to do. Some I buy and use, whatever suits my fancy as long as its a good product. For the gent above that gets his filters for $6 each; you have a good source/dealer. Hold on to him. Mine charges well over $8 for the oil, $43 for the transmission, and I didn't ask what the cost of the Hydro filter was. So, if any of you have cross refs for these latter two, I'd apprec knowing.
After NAPA came up empty, I did look on the Wix site and from there cross refed some others. Heres what I came up with. Must caution, I haven't seen any of them much less used any. Wix listed their filter for the Corvette 91-95 ZR-1 engine, as well as other makes, so I used that to get some of the foll:
Wix oil filter.......51324 16 PSI, 20 x 1.5 mm thread
NAPA.................1324
acDELCO...........PF970c semi-synthetic material
Purolator...........PL14619 8-16 PSI ( I think also semi-syn)
K&N..................HP2007
Champion..........PH2872A
Fram................PH2921
Bosch...............3430 synthetic material
Mobil1...............M1 207 Semi-syn
2025 10ft 18 Drawer 2 Cabinet Stainless Steel Workbench (A50325)
2025 10ft 18...
More info coming soon! (A50322)
More info coming...
2004 Ford Taurus Passenger Car (A51694)
2004 Ford Taurus...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A52748)
2017 KINZE...
