No Filters at NAPA for CK30
   / No Filters at NAPA for CK30 #1
ulflyer
lexington nc
CK 30H
Stopped by yesterday and they had very listings for KIOTI. Only an oil filter for the CK20 & 35. Zero for the CK30. :( If Napa doesn't have anything, then no one else is likely to either. I like to change oil more frequent than the book calls for. My old 24 YO Massy Ferg 3 cyl Japanese made tractor had about half doz or more aftermarket filters avail. Oh well........:p
   / No Filters at NAPA for CK30 #2
Somebody isn't trying very hard.
Strange NAPA didn't have it because it is merely a rebranded Wix. Wix shows they have your filter. Just looked it up on Wix.com. Easy. You can even find a store near you with their dealer finder.
http://www.wixfilters.com/filterloo...9&TempSubMake=651&TempModel=41501&TempEngine=
Not so sure the fella knew how to read his book very well.
   / No Filters at NAPA for CK30 #3
How about just purchasing kioti brand from a dealer??
Never hurts to support the brand right?
Joel
   / No Filters at NAPA for CK30 #4
I do belive the CK25,30 and 35 are the exact same engine other than displacement. So all the filters would be the same.
   / No Filters at NAPA for CK30 #5
I agree with JoalD. Buy your filters from your dealer. When I go in I get one Tranny filter and 4 oil filters, I change the filter with every oil change, and the tranny filter at the recommended 400 hours. I leave with around $10 left from a $50 bill. Oil filters are around $6 each. Pretty cheap if it helps the dealer stay in business so it's easier to get other parts when I need them.
   / No Filters at NAPA for CK30 #6
They may not stock it but the 1324 is correct. I walked into a NAPA and asked for a 1324 and 1347 they had neither. I was able to buy both at carquest. From Carquest its 85324 for the exact same filter. A different NAPA stocks both filters I just referenced as does my local Carquest.
   / No Filters at NAPA for CK30 #7
Just checked the Napa number for the engine oil filter number that I bought about a month ago. It is 1324. My closest dealer is over 2 hour drive away. Having said that I have ordered a set of hydraulic filters for my CK35 HST from my dealer in Oregon. :thumbsup:
If you can, as other posters have suggested, support your dealer. :)
   / No Filters at NAPA for CK30 #8
My Kioti, my wife's Tuscon, and my daughter's Elantra all use that 1324 filter. That makes it nice and easy on me to stock filters. :)
   / No Filters at NAPA for CK30 #9
The 1324 fit both cars that is awesome:thumbsup: I test fit one on my Rio with no luck. There was interference with the alternator bracket before the the filter was seated. So I will stick with the 1347/EAO36 filters, only slightly less capacity then a 1324.
Do not use a 1347 in place of a 1324 on your tractor. The 1324 has a bypass pressure roughly double that of the 1347 so the 1347 will go into bypass far sooner if used on a diesel.
Thanks guys for the feedback. When I got the CK30 I figured there would be lots of info on alternate filters. I always make a list of all brands that fit whatever vehicle I own; just something I like to do. Some I buy and use, whatever suits my fancy as long as its a good product. For the gent above that gets his filters for $6 each; you have a good source/dealer. Hold on to him. Mine charges well over $8 for the oil, $43 for the transmission, and I didn't ask what the cost of the Hydro filter was. So, if any of you have cross refs for these latter two, I'd apprec knowing.
After NAPA came up empty, I did look on the Wix site and from there cross refed some others. Heres what I came up with. Must caution, I haven't seen any of them much less used any. Wix listed their filter for the Corvette 91-95 ZR-1 engine, as well as other makes, so I used that to get some of the foll:
Wix oil filter.......51324 16 PSI, 20 x 1.5 mm thread
NAPA.................1324
acDELCO...........PF970c semi-synthetic material
Purolator...........PL14619 8-16 PSI ( I think also semi-syn)
K&N..................HP2007
Champion..........PH2872A
Fram................PH2921
Bosch...............3430 synthetic material
Mobil1...............M1 207 Semi-syn
KSI Conveyor (A52748)
Assorted Air Hose with Reels (A50325)
Assorted Air Hose...
Feather Brand Wooden Oar with Caviness Power Grip (A50325)
Feather Brand...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
2015 KENWORTH T880 MID-ROOF SLEEPER (A52472)
2015 KENWORTH T880...
New Holland B95 Backhoe (A50490)
New Holland B95...
