No crank no start Mahindra Emax 20s
   / No crank no start Mahindra Emax 20s #1
Roland Richberg
Mahindra Emax 20s
I have a 2019 Mahindra Emax 20s I bought used a few years ago. Has ran like a top until the other day. I cranked it up and started to back it under the shed to install wheel spacers on it. After installing them I went to start the tractor and move it back out from under the shed and it will not crank, turnover or start. I have checked the fuses, all safety switches, battery and ground to the frame, ignition switch all are good. I did notice no low voltage power, small wire, to the starter solenoid. I have power from the battery to the solenoid, bigger wire. I did run a jumper from the low voltage blade terminal on the solenoid straight to the ignition switch and the engine will turn over but did not start. I am at a loss at this point. Any help would be greatly appreciated.
I forgot I also checked the relays and they all tested good.
Charlotte County (A50323)
Charlotte County...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2025 12v Diesel Pump, Nozzle and Hose with Meter (A50323)
2025 12v Diesel...
