No crank no start Mahindra Emax 20s
   / No crank no start Mahindra Emax 20s #1
Roland Richberg
Mahindra Emax 20s
I have a 2019 Mahindra Emax 20s I bought used a few years ago. Has ran like a top until the other day. I cranked it up and started to back it under the shed to install wheel spacers on it. After installing them I went to start the tractor and move it back out from under the shed and it will not crank, turnover or start. I have checked the fuses, all safety switches, battery and ground to the frame, ignition switch all are good. I did notice no low voltage power, small wire, to the starter solenoid. I have power from the battery to the solenoid, bigger wire. I did run a jumper from the low voltage blade terminal on the solenoid straight to the ignition switch and the engine will turn over but did not start. I am at a loss at this point. Any help would be greatly appreciated.
I forgot I also checked the relays and they all tested good.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2014 JCB 930 (A57148)
Informational Lot - Financing (A56438)
Informational Lot...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
LOT: (9) Wheel Loader Shanks (A59076)
LOT: (9) Wheel...
John Deere 5055E (A53317)
John Deere 5055E...
