No crank no start Mahindra Emax 20s
   / No crank no start Mahindra Emax 20s #1
Roland Richberg
Mahindra Emax 20s
I have a 2019 Mahindra Emax 20s I bought used a few years ago. Has ran like a top until the other day. I cranked it up and started to back it under the shed to install wheel spacers on it. After installing them I went to start the tractor and move it back out from under the shed and it will not crank, turnover or start. I have checked the fuses, all safety switches, battery and ground to the frame, ignition switch all are good. I did notice no low voltage power, small wire, to the starter solenoid. I have power from the battery to the solenoid, bigger wire. I did run a jumper from the low voltage blade terminal on the solenoid straight to the ignition switch and the engine will turn over but did not start. I am at a loss at this point. Any help would be greatly appreciated.
I forgot I also checked the relays and they all tested good.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2018 Vermeer D23X30 S3 Navigator Directional Drilling Machine (A49461)
2018 Vermeer...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
H & S High Capacity Hayrake (A50515)
H & S High...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
