Disc Harrow No bearings
   / No bearings #1
Texomahog
Ada, Oklahoma
Mahindra 2538
Does anyone know if any company still makes a disc without bearings?
   / No bearings #2
Are you referring to the type of bearings with small balls or rollers in them? If so my land pride disc does not have them. I suspect many do not. It just looks like they do.
P.S. Well it seems I made two mistakes. First one is that I have a woods brand and for my second mistake it does have sealed bearings.
Used to use a friends old disc and I had to do some work on it and I guess that the one I am remembering since I was surprised by assuming all would have bearings. No idea what brand it was.
   / No bearings #3
Not sure but try everything attachments --I checked and they do use roller bearings
   / No bearings #4
I have a light duty Land Pride DH1048 - it has sealed ball bearings. Redlands Okie - check you owners manual - I'll bet you have sealed ball bearing also.
   / No bearings
I have had a 4 ft. disc for several years that has no bearings what so ever. I bought it from a dealer in OKC who told me he recommended it because I only use it twice a year for deer plots. After about three hours of use, you just pump more grease in it. The dealer recommended it because he said only using it twice a year I would have problems with the bearings as it is stored in a large open shed and does get a lot of moisture. I am pretty sure it is a Chinese made implement, but, it has worked great and was dirt cheap. I am about to bet a much bigger tractor and will need a larger disc. I looked on line and could not find anything without bearings. By the way, I am buying a Mahindra and their discs have sealed bearings. Would that be okay stored in a wet environment as I can get it at a much reduced cost when buying the tractor.
Than you guys!
   / No bearings
Rick, excuse my ignorance. I assume what I meant was ball bearings, am I correct?
   / No bearings #8
Than you guys!
I have a 6 ft. that's a good 25 plus years old that must be like your 4 ft . I use to load it up with cement blocks and haul it behind my m5700 until I got the 2650 . It has no roller bearings either just some grease fittings I grease once a year . It has had some use as we had market gardens at one time . I'm surprised it is still going strong seeing as this has what is called friction bearings and takes a lot of grease each time I do grease it .
   / No bearings #10
Don’t think you’ll find a larger new disc with the cast bearings. I have a older Massey disc with sealed bearings, that has set out for the last 20 years, used to disc 4-5 acres a year or so and have not had any bearing failure.
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
43002 (A51691)
43002 (A51691)
Bad Boy 747cc Outlaw (A50121)
Bad Boy 747cc...
CATERPILLAR GP30 STRAIGHT MAST FORKLIFT (A51242)
CATERPILLAR GP30...
Toyota 42-6FGU25 Forklift (RUNS) (A50774)
Toyota 42-6FGU25...
UNUSED FUTURE MINI SKID STEER HOLLOW WOOD GRABBER (A51244)
UNUSED FUTURE MINI...
