No 4wd LB1914
/ No 4wd LB1914 #1
lmbrsn
Bakersfield, CA
Kioti LB1914 IH 674
Help I heard some popping sounds from under my tractor and now I have no 4wd.
What is the easiest thing to look for first. I have the manuals and am reading them now.
Has anybody else lost the 4wd on a LB1914?.
Any help would be appreciated.
Thanks Jim
/ No 4wd LB1914 #2
Jim, Not able to help. Just hope to follow this thread as purchased my LB1914 in spring 2002 and have not had anything fail so far. Guess I would start at the linkage from the control and see where that leads.
/ No 4wd LB1914 #3
If it is anything like my LK3054 there is a pin in the drive shaft to the front end. You may have to check and see if the pin broke. see if the shaft is turning.
/ No 4wd LB1914
I put the front end up into the air and turned the wheels and everything sounded good and turned the right way with no noise. I am hoping that it is just the pin that broke. will let you know.
Jim
/ No 4wd LB1914 #5
Make absolutely sure the lever is all the way in 4wd.
Maybe even edge forward and push at the same time.
The 1914 if well cared is a very tough little machine.
BTI
