no 3 point
/ no 3 point #1
jimandapril97
We have a dongfeng/field pro 354 and the 3 pt hydraulics quit working. The pump still works the loader bucket. Any ideas? Is there some kind of safety cutoff that could have been triggered? Jim
/ no 3 point #2
Since no body else is answering, I'll give it a shot.
You might get better info by posting in the chinese tractor forum.
I've never seen a dongfeng, but I do have a Kama TS254. The Kama and all of the other chinese tractors that I have seen use a self contained 3pt hitch lift box with an internal valve and cylinder. There is ussually a knob that controls the drop rate of the 3pt hitch, and a bolt on the side of the lift box that diverts the fluid flow from the lift box to a remote. If your tractor has these that is where I would start. Either one too tight will cause the 3pt to stop working.
On my Kama I had a problem with the 3pt not working. My problem was caused by an O-ring blowing out in the control valve. I found the problem by taking the cover off of the lift box, and starting the tractor. No matter where I positioned the 3pt lever, oil was running out of the control valve. It was a fairly easy repair, once I found the problem.
Stan
Fuel Storage Tank (A68134)
Fuel Storage Tank...
2005 LUFKIN 45'X102" FLATBED TRAILER (A67714)
2005 LUFKIN...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
CATERPILLAR 312D EXCAVATOR (A65056)
CATERPILLAR 312D...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
