"Nilight" leds?
/ "Nilight" leds? #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
Anyone ever heard of Nilight LED's? Anyone ever used them? Amazon has a good price for them. I made a light bar for the front of my tractor for snowplowing and left spots for 4 lights. Thought about getting 2 flood and 2 spot lights, 18 watts. If not I will probably go with the TUFF lights, but maybe I only need 2 of them since they are supposedly 27 watts.
Edit... Here's a link to the spot version.
Amazon.com: Nilight® 2 X 18w 1260lm Cree Spot Led Work Light Bar Off-road SUV Boat 4x4 Jeep Lamp 4wd: Automotive
/ "Nilight" leds? #2
Mike, I have lights that are (from the looks of them) identical to what you posted. I'm thinking they just added the words "Nilight" on the sides of the lights. Made in China of course. I've never had an issue with my lights that have been on my tractor for about 6 months now. Hope this helps. Stanley
/ "Nilight" leds? #3
LED's are the way to go for sure.I put two 18 watt on the front to replace the Halogens,plenty of light.Two 27watts would be like daylight.I have installed LED's on both tractors,my Rhino and boat...love'm.
/ "Nilight" leds? #4
These look good for the price.
/ "Nilight" leds? #5
I have some crees that are a little bigger than those and love them.
/ "Nilight" leds? #6
Here is what the 2 TuffLeds on front and 1 in back look like from my scut cab.
/ "Nilight" leds? #7
wow,they look bright.care to share some info. On these? Wattage,price and where they came from? Thanks
/ "Nilight" leds? #9
Here is a link to Amazon with all of the details
Amazon.com: TUFF LED LIGHTS 4 Inch Square 27watt LED Work Lamp Light 1550 Lumen, Off Road, Atv, Utv, Polaris Ranger (pack of 4 ): Automotive
Super Bright Long Life Tuff LED Technology **** Features: - 4 x 4 27watt Super White TUFF LED's - Suits 12V vehicles - 2150 Lumen output - Super Bright TUFF XLT Latest LED technology - up to 120,000 hours of life - Ultra Low current draw, won't drain your battery - Tuff LED® Powder coating provides 100% Sealed lighting system, resistant to moisture, dirt and dust ingress - Almost no heat produced, safe for confined work spaces - Stainless steel mounting kit - IP67 rated - Special Heat treated Tuff LED® Cast Aluminum Alloy Housing - Pre-wired with 400mm of double insulated cable ******** Specifications:*** Model: 72WS101 Size: 4.57*4.57*2.4 inch (4") Multi Voltage: 10-30V Power: 27W (3W*9pcs High Power TUFF LEDs) Color: White Lum: 1550 Beam Distance: 164 FT - 364 FT Life Time: 50,000 - 120,000 Hours Working Temperature: -45 ~85°C ****** Application: Auxiliary lamp for SUV ,UTV ,ATV ,Racing ,Truck ,Agricultural vehicles , Heavy Machinery etc Dimensions 109mm x 109mm square Depth: 37mm *********** Installation The lamp features stainless steel mounting hardware plus alloy brackets for mounting to flat surfaces. This allows the lamp to be used as an interior roof or wall lamp inside enclosed trailers or canopy.
/ "Nilight" leds? #10
My Kubota has 2 lights on the front, 2 on back and 1 on each side. All of them are flood pattern for a wide lighted area close to the tractor. Lighting something up bright 100 yards away has no appeal. What matters most is being able to see things near the tractor. In the picture below, what looks like a dark stripe in front of the tractor is darker vegetation that covers the gravel aux driveway to the shed at different times of the year. There is a darker area behind the mower. Re-aiming the rear lights would probably eliminate that, but the overall pattern is OK as is.
/ "Nilight" leds? #11
I've found the diffusors used in LED's are poor and the difference between a flood and spot are negligible regardless of what the spread claimed is. I tested a couple of the lights I just got using a 9v battery and a single bulb easily lit up my 440sq ft garage (and still blinded me).
2025 KENWORTH T880S DUMP TRUCK (A63276)
2025 KENWORTH...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
1996 Aspen FP601 T/A Fracking Pump (A64194)
1996 Aspen FP601...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
