Rotary Cutter nicest finish from a non-grooming rotary cutter?
   / nicest finish from a non-grooming rotary cutter? #21
The Cushman 6150
   / nicest finish from a non-grooming rotary cutter? #22
And the Cushman after a little oopsie!
It has four wheel drive but practically racing slicks!
   / nicest finish from a non-grooming rotary cutter? #23
I think you would be hard pressed to find a twelve foot flail mower. It would have to be in sections. Even a six foot has trouble is the ground is not perfectly level. I just got rid of a sixteen (or fourteen?) foot Alamo finishing wing mower. It would have done what you wanted. It had high blade speed and rear discharge decks. I ran it with a 68 PTO tractor which was a little too much I always thought. But then when trying to sell it, we tried a 45 PTO HP tractor and it wasn't enough.
About that;
NOPE; a good 12 foot flail shredder does not fold like cheap suit.
They are all built as a one piece unit with tubular construction surrounding the flail mower shroud.
Brillion, Loftness, Vrisimo, Massey Ferguson and Woods have 12 foot flail shredders)
woods and massey are the same(model designations are exact) and woods makes their
12 foot flail crop shredder.
This does not include the excellent flail shredder imports that are available like the wider Machio flail shredders and the INO folding 2 and 3 section heavy crop shredders that have been in use for many years.
These units are designed for smaller European roads and farm fields and they are very well built and surpass the towed/mounted implement safety standards of the United States FEMA organisation-Farm Equipment Manufacturing Association.
I just do not want to see him become discourged after recieving bad to worse advice from dealers and others as he has limited free time to manage his property and a 12 to 15 foot crop shredder will barely yawn at heavy growth while mowing and the 2 inch height he wishes to have will be no problem even mowing wet grass or brush that a rotary mower or rotary cutter cannot manage.
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A55745)
2006 V.E...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55302)
NEW HOLLAND 706 30...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
202473 (A54757)
202473 (A54757)
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
