NH TS100 Error Code Help
/ NH TS100 Error Code Help #1
SunHeart
Central NY
Antonio Carraro TTR 3800 HST
I am looking at purchasing a NH TS100. When taking it for a test drive an error code came up on the dash - E59. Seems to have to do with the hydraulic fwd/reverse shifter on the steering column. It happened when after running the tractor forward for a good run, I would shift it back to neutral, and then the code would come up. As soon as putting it back into forward, or reverse, or depressing the clutch, it would go off. Looking around online it seems to be connected to 'FRNP in illogical state' (two positions on at same time).
Has anyone experience with this? Any thoughts on if it might point to a deeper problem, or rather some malfunctioning electric parts or needing some lubrication so the shifter moves into the correct place?
It only seemed to happen when I was in high range, if that makes a difference.
/ NH TS100 Error Code Help #2
Have you asked the seller or your local New Holland dealer's service people? That's what I'd do.
AGT Industrial SDA-140T (A64127)
AGT Industrial...
TRUCK RAMP (A64556)
TRUCK RAMP (A64556)
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
(10) New CATERPILLAR Keys (A65579)
(10) New...
