NH TS100 Error Code Help
/ NH TS100 Error Code Help #1
SunHeart
Central NY
Antonio Carraro TTR 3800 HST
I am looking at purchasing a NH TS100. When taking it for a test drive an error code came up on the dash - E59. Seems to have to do with the hydraulic fwd/reverse shifter on the steering column. It happened when after running the tractor forward for a good run, I would shift it back to neutral, and then the code would come up. As soon as putting it back into forward, or reverse, or depressing the clutch, it would go off. Looking around online it seems to be connected to 'FRNP in illogical state' (two positions on at same time).
Has anyone experience with this? Any thoughts on if it might point to a deeper problem, or rather some malfunctioning electric parts or needing some lubrication so the shifter moves into the correct place?
It only seemed to happen when I was in high range, if that makes a difference.
/ NH TS100 Error Code Help #2
Have you asked the seller or your local New Holland dealer's service people? That's what I'd do.
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2015 TRANSCRAFT DTL300 48X102 TRI/A DROP DECK TRAILER (A59909)
2015 TRANSCRAFT...
2022 Kubota 74in. Hydraulic Dual Cylinder Grapple Skid Steer Attachment (A61567)
2022 Kubota 74in...
