NH TS100 Error Code Help
   / NH TS100 Error Code Help #1
SunHeart
Central NY
Antonio Carraro TTR 3800 HST
I am looking at purchasing a NH TS100. When taking it for a test drive an error code came up on the dash - E59. Seems to have to do with the hydraulic fwd/reverse shifter on the steering column. It happened when after running the tractor forward for a good run, I would shift it back to neutral, and then the code would come up. As soon as putting it back into forward, or reverse, or depressing the clutch, it would go off. Looking around online it seems to be connected to 'FRNP in illogical state' (two positions on at same time).
Has anyone experience with this? Any thoughts on if it might point to a deeper problem, or rather some malfunctioning electric parts or needing some lubrication so the shifter moves into the correct place?
It only seemed to happen when I was in high range, if that makes a difference.
   / NH TS100 Error Code Help #2
Have you asked the seller or your local New Holland dealer's service people? That's what I'd do.
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A53421)
2025 GIYI GY-ZWB...
