NH TN 65 - Looking to buy - looking 4 input good/bad
   / NH TN 65 - Looking to buy - looking 4 input good/bad #11
I have a TN75DA (cab) with FEL, and powershuttle
FANTASTIC tractor.
Great ergo's (much better than most other same size utilities.
TONS of power, even up here at altitude. I had it on the PTO dyno at the shop, it pulled 67 PTO HP, at 5000 feet. (turbo's rock)
As you noted a utility is significantly cheaper to run long term than a compact. It pulls an 8' mower without ever bogging (and I go 5mph), could easily pull a 10' or 12'. (a batwing might be pretty slow). Easy to hook things up, the controls just come to hand. I love the quick lift feature, I use that a lot.
And me, the man who has everything break on him, hasn't managed to have the TN fail me (except when it was my fault, can't blame it for that).
I can go all day at PTO speed (pulling the mower above) on one tank of fuel.
It doesn't turn near as well as the TC series, but it's a much bigger tractor.
I'd buy another
HTH
   / NH TN 65 - Looking to buy - looking 4 input good/bad #12
I just bought a TN75 like LCs exc w/o a cab. I only have a hand full of hours on it though so I cant really say one way or the other. Problems to date are leaking coolant hose, nonoperational fuel gage and a noise which comes/goes that sounds like a bad bearing. The coolant hose was fixed but the dealer says he cant hear the noise which sounds like a bad bearing. I havent yet brought the fuel gage to the dealers attention but thought it might be as simple as a stuck float which I might be able to fix. Most of what Ive done so far is some mowing here/there to shake out problems before next yrs hay season.
   / NH TN 65 - Looking to buy - looking 4 input good/bad #13
Roper14 said:
I apologize anyone for the misleading..I type the way I talk...rambling man...
Rambling man, I likke that. I ramble too:D
Back to what you are going to use it for, will it be on hills? If yes, describe. Wet ground? I ask, since I use mine to Bush Hog around some marshes, and having FWA really helps when I get stuck in 2 wheel drive.
So, is all your work on level ground or what? We need to know more to help you spend your money.
Bob
The feedback on the TN series is great...I'm talking with the guy that owns the TN 65 - now if we can just get straight on the $$$
As far as usage, I own a cute "little" :cool: 30 acre hay pasture that is about as flat as can be. Downside is that it does retain moisture a little bit (crawfishy) but does grow grass REALLY well and I am one of few people that will have green grass throughout a dry summer. After 6 years of "borrowing" tractors I have yet to get stuck and really have never used the 4wd on the 4wd models that I borrowed (try not to get in those situations). Yet I also will not be using a tractor except every now and then during the winter because of "no" livestock (just horses - no round bales to feed).
So essentially just bushhogging (w/the largest bushhog possible, blading, dragging an arena, and so forth...typical minor tractor chores) One thing I have run into over the past 4-5 months of hard tractor "shopping" is that the 4wd owners are very proud of what they own, no matter how many hours or how old....and everybody want one:) , so typical theory is that the 2wd models should be "less" (we'll see)
for example...how about a 15 year old HESSTON 4wd 65hp w/loader, 3k hours, $12500. ouch. maybe buy it for $11,500 still a little pricey for my taste, others may think bargain, not me......I would either try to find something less than 1000 hrs at around 60% of cost (or less)....or I believe that I would be better off buying a new tractor.....that is just the way I believe the tractor market is these days.........
any thoughts what a 2003 TN65 w/loader 8X8 300 hrs 2wd is worth (what a good deal would be - he's thinking around $15k, I'm a little stubborn).....
   / NH TN 65 - Looking to buy - looking 4 input good/bad #15
I did a quick check online, only found one 2003 TN65 2wd w/loader so far, 3865 hours, priced at $16800. 2000 TN65 2wd w/loader, 108 hours, $19950. 2007 2wd TT60A w/loader, 101 hours, $14800. May not be a lot of help, but can give a general idea of dealer pricing. Personally, I don't see $15k as being a bad deal with low hours. That tractor new is likely $22-23k, maybe more. I'm seeing a lot of 2wd non-loader tractors for about $15k.
   / NH TN 65 - Looking to buy - looking 4 input good/bad #16
I bought a used TN65 4 x 4 with loader, canopy, 8 forward/reverse in 2004 and I love it. Had 206 hours on it; I now have 775 hours on it. Pulled a 3-bottom, 16-inch plow with no problem. Also use a 12 foot tandem disk, 9 foot haybine, round and square balers with no problem.
And...I had it shipped 500 miles from it's home in NH.
Can't go wrong with a TN65, even with the 2WD. I do loader work with it in 2WD, although I do have weight on the rear.
Good luck!!!
   / NH TN 65 - Looking to buy - looking 4 input good/bad #17
Good luck!!!
I bought a used TN70A (2003) FWA and learned the hard way that weight on the rear is vital to FEL. Being self taught is tough! But I love my TN. Tough tractor that does everything I need.
DOC
   / NH TN 65 - Looking to buy - looking 4 input good/bad #18
Stubborn is good. You will know when it is the right tractor and the right price. Take a look at this one and just learn from looking at it. Sometimes you have to drive a distance and walk away empty handed.
Bob
DOC
That was one question I asked about the TN 65 (and may or may not have gotten the "right" answer) because I have been around a TL 90 before ( a totally different tractor hence the reason for asking about the TN's) yet it too was also a little light in the back end when we would pick up hay...ended up having to fill up the back tires.....yet I was told "never had a problem" with the TN so they may had never picked up anything really "heavy" or it truely did not have any problems----- the way I look at it, I can get by with that if that is the only issue with the tractor....(put anything on the back end - or put water/antifreeze in tires)..........thx for the input on the tractors and $ range
   / NH TN 65 - Looking to buy - looking 4 input good/bad #20
ALL tractors need to be "balanced" for every situation. Don't be fooled into thinking otherwise. I was until the school of hard knocks taught me otherwise.
In other words, enjoy balancing the tractors front/rear weight distribution, no matter what tractor you buy.
Bob
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
UNUSED JCT QUICK ATTACH 72" HYD 4N1 COMBO BUCKET (A51244)
UNUSED JCT QUICK...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
Blue-Jet Liquid Fertilizer Applicator (A51039)
Blue-Jet Liquid...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
