cdcastle
New owner of new holland 2000 TL100. Factory set of 3 rear remotes with an aftermarket KD QT6400 Front loader. previous owner installed loader and connected the loader hydraulics to one set of the rear remotes. I believe the rear remotes are CCLS type. Problem- I have to manually move the lever inside the cab back to the neutral position in order to run the loader. I can't use the the 3 point unless I move the lever out of the rear position. In other words I can't use the loader or 3 point without manually moving the lever-- which is very annoying while doing work-- (my smaller 3930 ford has live action all the time to the 3 point and the loader- without making any changes)
- I want my TL100 to work the same way. So, when looking at the TL100 I see the main hydraulic supply coming from the engine mounted pump as it goes to the back of the tractor it plumbs into a hydraulic manifold supplying oil to all the various functions-- can I disconnect this line and redirect it directly to the loader control valve ,and then send the power beyond port outlet of loader control valve back to the hydraulic manifold . This would basically make the fel loader valve see hydraulic oil first , and then the tractor gets its oil. I've read there may be a problem with the load sensing aspect ? Something about maybe needing a shuttle valve? Am I all wrong, or is there a simple way to do this.
