NH TC35da
/ NH TC35da #1
JMER
N Alabama
GC2600
Hi all I'm considering a TC35DA hst with about 589 hrs asking $15k. I'm hoping to get them down to $13,500/$14k. My question is this. They have a boomer 250tl loader on it which when I look at the specs has a good bit more capability than the loader that normally comes with the TC35DA..will this loader they have on it still perform up to its specs even though it's not on the boomer tractor it was designed for?
/ NH TC35da #2
It may not operate up to the rated speeds; time to lift full load to max height, full curl to full dump time, etc... It will still lift the full weight capacities, just not as quickly if the hydraulic flow (GPM) is less. Also, if the tractor it was made for is a different height, there will be a difference in the overall lift height as well.
/ NH TC35da
perfect that all makes sense, thank you! I'm not real concerned with the speed, mainly the breakout force and lift capacity.
/ NH TC35da #4
It is the correct loader. At the time the 16LA loader was used on the TC35/40/45 series. The 16LA is no longer available. The 250TL is the model that replaced the 16LA. It has 200# more lifting capacity, 1800# vs 2000#, but that should not be an issue with operating the tractor or loader. On the brighter side parts availability should not be an issue.
/ NH TC35da
Ahhhh, gotcha, thank you sir.
2024 JCB 35Z (A60462)
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
UNUSED 1RMC HIGH END MASSAGE CHAIR (A64281)
UNUSED 1RMC HIGH...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
