NH TC30 Owners:
   / NH TC30 Owners: #31
My TC30 has always done what I have asked of it, with no complaints. I use a woods BH and 7308 FEL. I have used it to remove stumps and concrete walkways to just cutting the grass. I think the TC30 is a small workhorse to be reckoned with.
   / NH TC30 Owners: #32
i have had my tc-30 for 3 years now and just a few problems in the begining with hydraulic hoses but other than that the tractor is great does what ever i put in front of it it just takes a little longer, remember it is not a big cat loader.
   / NH TC30 Owners: #33
Love my tc30
I push it hard and ask alot of it . have had only 1 prob with it but it was covered under warranty. would buy again in a flash.
Tractors are not just for work , there an obsession lol:)
   / NH TC30 Owners: #34
The TC30 is basically the old 17hp Ford 1320 with a big engine. My 1320 has been a fantastic tractor but I would be a little concerned putting a heavy load to it. It appears most manufacturers have used the smaller chassis and added larger engines which could spell trouble.
With out any engine mods to increase hp. I've pulled a 2 bottom 12 in. plow for years. A 56" tiller and an older Ford 2 row corn planter. Add 10 more hp on the same clutches? Not me!
   / NH TC30 Owners: #35
1320 was same as 1520 and 1620; just more HP. TC 30 should be fine.
   / NH TC30 Owners: #37
Ive had mine for 9 months and would not trade it for the world. Its got the 9x3 trans, 4x4, front end loader, brush hog and box blade. Pd 15500.00. it has done everything I want it to do. I have not even made it to my 50 hr service yet, but getting close. I would recommend it if the size is for you. Later, John
   / NH TC30 Owners: #38
I have had mine for just over three years - 233 hours on it. It has a 7308 loader, 72" ganon, manual trans - 4x4, it gets used every weekend to move 3 tons of manure, move hay bales between pastures, and several times a year to rip the pastures, and level the driveway. Only failure to date has been the joystick / valve for the loader, it failed just before the two year mark and was not covered by the warrranty. It gets parked in the garage, while the new car gets parked outside !!
   / NH TC30 Owners: #39
16 months and 116 hours on my 2006 Tc 30 Going Great. One thing I am curious about is the oil filter on my 2006 it is not vertical like some I have seen. I have to remove the side cover. Not a big deal but just curious what years were Vertical??? One small issue the paint on the loader control valve cover started flaking off in sheets due to improper prep at the factory. I guess I could have called the Dealer but I just removed it sanded to bear metal and repainted. To me this is a much better looking machine than a regular Boomer. I like the traditional look.
Storeman
2006 TC 30/7308 Loader,4' KK Roto Tiller,5' Brush Bull Rotary Cutter,Bush Hog 6-50 Hvy duty Road Blade, Old Rusty Disc, The best option of all DELTA QUICK HITCH SYSTEM.
   / NH TC30 Owners: #40
vertical oil filter; have not seen one. The hydro filter is vertical on the left side of unit. Oil filter is on right side of unit.
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2009 UTILITY TRAILER MFG. CO. SEMI TRAILER 57 (A50854)
2009 UTILITY...
Flatbed Body for Heavy Truck (A50854)
Flatbed Body for...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
