NH TC29DA CLUTCH PEDAL RETURN SPRING BROKEN
   / NH TC29DA CLUTCH PEDAL RETURN SPRING BROKEN #1
ranger13256
northville, ny
New Holland
Is there a best "easy" way to replace the clutch pedal return spring on a 2005 NH TC29DA tractor?
   / NH TC29DA CLUTCH PEDAL RETURN SPRING BROKEN #2
I don't know about the TC29; the spring broke on my JD 790. It was a simple process, just some parts to remove to get to it. Have you looked at your clutch pedal system to see how to access it?
I did see that post, however it is quite a bit different than mine. It is under the floor so I will attempt to try installing under from underneath. I hope to do it without tearing the whole pan etc. Thanks for the reply/
   / NH TC29DA CLUTCH PEDAL RETURN SPRING BROKEN #5
Just a general suggestion... Depending on access and how tight that spring is, consider attaching some heavy string or steel wire to the spring to pull it on.
I had to do that on a neighbor's mower deck some years ago to stretch a very tight idler pulley spring.
Thank you, very good suggestion as the spring does look very tight.
   / NH TC29DA CLUTCH PEDAL RETURN SPRING BROKEN #7
I suspect from reading the attached that you are going to need to separate the tractor. Hopefully others with more knowledge can confirm this.
  • Single Clutch.pdf
   / NH TC29DA CLUTCH PEDAL RETURN SPRING BROKEN #8
Here is the page from my TC40DA repair manual. If your setup is similar, disconnecting the brake pedal rods may let you rotate the assembly to give you some slack on the spring #4.
   / NH TC29DA CLUTCH PEDAL RETURN SPRING BROKEN #9
Clutch pedal return springs under the L side of the footplate. Case/IH DX29 &/or NH TC29DA HST. (9 X 3 similar)
All fixed. NH part # 86530740 did the trick. I used braided picture frame wire and a brake pedal depressor tool used to check lights which ratchets. One end of the spring in the bottom of clutch pedal and the other end in the wire and ratchet it until it lines up with the hole in the bracket and just push it in. Took 2 minutes once I got set up. Thank you for the replys especially the wire one!
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
