Backhoe NH T1530 Compatible Backhoe
   / NH T1530 Compatible Backhoe #1
new jersey mike
NJ Home with property in East Worcester, NY
2010 - NH T1530
I have a 2010 T1530 I am confused if my tractor can have a 3pt backhoe attached or not.
I was under the impression it could not but now I just not sure. So if you know this answer and which mfg and model that would be great.
Thank you.
   / NH T1530 Compatible Backhoe #2
I am not sure about a 3pt backhoe but Brushhog has a frame mounted. Model Number BH750 or BH650 listed with a subframe mount that attaches to a 1530.
Subframe Kit P/N 50036455 (Used On Tractor Models Ford/NewHolland 1530, 1630, 1725, 1925, TC25, TC250, TC29, TC290, TC33, TC330 Case/IH D25, DX25, D29, DX29, D33, DX33 With Bush Hog 2246QT Loader Or Great Bend 244 Loader)
OR
Subframe Kit 50036455 for Bush Hog Backhoe Models BH650 and BH750 used on Tractor Models Ford/NewHolland 1530, 1630, 1725, 1925, TC25, TC250, TC29, TC290, TC33, TC330; Case/IH D25, DX25, D29, DX29, D33, DX33 Use with Bush Hog 2246QT Loader
I personally prefer a subframe mount as it provides additional rigidity to the tractor. I have a Bradco subframe mount on my TC33D and love it. The first time taking it off and back on was a little time consuming but now it goes pretty quickly. The big thing is to do it on level ground.
I suspect that Bradco has one as well but couldn't find any fitment info.
Good luck
Gerry
:thumbsup:
OR
Good luck
Gerry
:thumbsup:
Oh this is great I will look into the info, I thought I was mistaken.
Thanks.
   / NH T1530 Compatible Backhoe #4
A NH T1530 is not the same as a older Ford/NH 1530. These are 2 totaly different tractors. Make sure get get the specs for a T1530. I will never figure out why NH keeps changing the numbers on these tractors.
Bill
   / NH T1530 Compatible Backhoe #5
Uh oh I forgot all about those hope you will still be able to find an subframe that will work. I am sure a call to Bush Hog or Bradco will be able to straighten that out.
   / NH T1530 Compatible Backhoe #6
The T1530 definitely needs a subframe. Tractors under 50-60 hp typically should use a subframe and this one being an economy version is built lighter. I think NH offers the 920GH and 930GH for it (with subframe). Might check Rhino out as they make the backhoes for New Holland.
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
SKID STEER GRAPPLE BUCKET (A58214)
SKID STEER GRAPPLE...
Ford 8510 (A53317)
Ford 8510 (A53317)
