Backhoe NH T1530 Compatible Backhoe
   / NH T1530 Compatible Backhoe #1
new jersey mike
NJ Home with property in East Worcester, NY
2010 - NH T1530
I have a 2010 T1530 I am confused if my tractor can have a 3pt backhoe attached or not.
I was under the impression it could not but now I just not sure. So if you know this answer and which mfg and model that would be great.
Thank you.
   / NH T1530 Compatible Backhoe #2
I am not sure about a 3pt backhoe but Brushhog has a frame mounted. Model Number BH750 or BH650 listed with a subframe mount that attaches to a 1530.
Subframe Kit P/N 50036455 (Used On Tractor Models Ford/NewHolland 1530, 1630, 1725, 1925, TC25, TC250, TC29, TC290, TC33, TC330 Case/IH D25, DX25, D29, DX29, D33, DX33 With Bush Hog 2246QT Loader Or Great Bend 244 Loader)
OR
Subframe Kit 50036455 for Bush Hog Backhoe Models BH650 and BH750 used on Tractor Models Ford/NewHolland 1530, 1630, 1725, 1925, TC25, TC250, TC29, TC290, TC33, TC330; Case/IH D25, DX25, D29, DX29, D33, DX33 Use with Bush Hog 2246QT Loader
I personally prefer a subframe mount as it provides additional rigidity to the tractor. I have a Bradco subframe mount on my TC33D and love it. The first time taking it off and back on was a little time consuming but now it goes pretty quickly. The big thing is to do it on level ground.
I suspect that Bradco has one as well but couldn't find any fitment info.
Good luck
Gerry
:thumbsup:
OR
Good luck
Gerry
:thumbsup:
Oh this is great I will look into the info, I thought I was mistaken.
Thanks.
   / NH T1530 Compatible Backhoe #4
A NH T1530 is not the same as a older Ford/NH 1530. These are 2 totaly different tractors. Make sure get get the specs for a T1530. I will never figure out why NH keeps changing the numbers on these tractors.
Bill
   / NH T1530 Compatible Backhoe #5
Uh oh I forgot all about those hope you will still be able to find an subframe that will work. I am sure a call to Bush Hog or Bradco will be able to straighten that out.
   / NH T1530 Compatible Backhoe #6
The T1530 definitely needs a subframe. Tractors under 50-60 hp typically should use a subframe and this one being an economy version is built lighter. I think NH offers the 920GH and 930GH for it (with subframe). Might check Rhino out as they make the backhoes for New Holland.
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A58214)
2013 XLR...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2016 Ford F-350 (A56858)
2016 Ford F-350...
30KW GENERATOR (A58214)
30KW GENERATOR...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
