NH/MA G154 G174 tx1300 TX1500 TX2140 TX2140
   / NH/MA G154 G174 tx1300 TX1500 TX2140 TX2140 #71
Hi guys, I am up in the Burlington VT area and recently purchased a G174. It is a little rough around the edges but seems like a real nice tractor. I am currently having an issue with high gear though. I will get some pictures of the tractor up soon.
   / NH/MA G154 G174 tx1300 TX1500 TX2140 TX2140 #72
If you live in New Hampshire, Massachusetts or other New England state
and have a compact Bolens Iseki which goes under many names
G154 G174 tx1300 TX1500 TX2140 TX2160
G152 G172 tx1304 TX1504 TX2140F TX2160F TX1510
Let us know !
Hi im new to the Iseki crowd just picked up a TX1500F it is cosmetically challenged to say the least you say all these model numbers have more or less the same body parts because I'm looking for a bonnet and grill just wondered if any of these bonnets would fit
   / NH/MA G154 G174 tx1300 TX1500 TX2140 TX2140 #73
I have an early Bolens G154 which is an Iseki TX1300F. It has a 2 cylinder engine.
I read somewhere that a 3 cylinder engine model tractor has a longer bonnet
which would make sense because of the extra cylinder. So not all bonnets are
the same length.
   / NH/MA G154 G174 tx1300 TX1500 TX2140 TX2140 #74
the same length.
yes that does make sense thank you
   / NH/MA G154 G174 tx1300 TX1500 TX2140 TX2140 #75
The three cylinder hood/bonnet is about 2.5 cm longer. Almost indistinguishable visually but enough to not work without modification. The rest of the sheet metal components appear to be interchangeable. The transmissions are different too and are not compatible with the engine bolt patterns (i.e. 2-cylinder engines only bolt to the transmissions they originally came with and vice versa unless you want to try your hand at difficult adaptations).
   / NH/MA G154 G174 tx1300 TX1500 TX2140 TX2140 #76
Thanking you sir I’m not very good welding tin work so I think I’ll keep looking for a 2 cylinder bonnet that will fit anybody out there got one going?
Thanks again
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2006 JCB 520 Telehandler (A59213)
2006 JCB 520...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2007 Toyota Camry Sedan (A56859)
2007 Toyota Camry...
2013 CATERPILLAR 336E L (A58216)
2013 CATERPILLAR...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
