Oil & Fuel NH M135 HYDRAULICS
   / NH M135 HYDRAULICS #1
dommas
south africa
new holland
HI GUYS, I NEED SOME HELP PLEASE. I HAVE A NEW HOLLAND M135 , I FITTED NEW HYDRAULIC OIL FILTERS AND OIL , NOW I CANT GET RID OF AIR IN THE SYSTEM. PUMP MAKES A BAD HUMMING SOUND AND THE TRACTORS 3 POINT, POWERSTEERING ETC. IS NOT FUNTIONING CORRECTLY. THE FILTERS HAVE OIL IN, AND LOGIC TELLS ME THAT IT SHOULD BLEED ITSELF . CAN THE PUMP BE CAVITATING? BUT WHY NOW? ARE THERE ANY BLEEDING SCREWS THAT I DONT KNOW OF MAYBE?
THANKS
DOM
   / NH M135 HYDRAULICS #2
If the IN port of the pump is flooded, and is not sucking air, the hyd system should self bleed with operating all valves many times.
Hi JJ
Thanks a lot, will do so and keep you updated. Can it be pump failure? Or a solenoid that is stuck open or closed?
Cheers
Dom
2019 Ford F-550 Truck 4x4 Crew Cab Palfinger PSC6025 3 Ton Crane Service Truck (A55973)
2019 Ford F-550...
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2011 BMW 750Li Sedan (A55973)
2011 BMW 750Li...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2013 Ford F-150...
