Oil & Fuel NH M135 HYDRAULICS
   / NH M135 HYDRAULICS #1
dommas
south africa
new holland
HI GUYS, I NEED SOME HELP PLEASE. I HAVE A NEW HOLLAND M135 , I FITTED NEW HYDRAULIC OIL FILTERS AND OIL , NOW I CANT GET RID OF AIR IN THE SYSTEM. PUMP MAKES A BAD HUMMING SOUND AND THE TRACTORS 3 POINT, POWERSTEERING ETC. IS NOT FUNTIONING CORRECTLY. THE FILTERS HAVE OIL IN, AND LOGIC TELLS ME THAT IT SHOULD BLEED ITSELF . CAN THE PUMP BE CAVITATING? BUT WHY NOW? ARE THERE ANY BLEEDING SCREWS THAT I DONT KNOW OF MAYBE?
THANKS
DOM
   / NH M135 HYDRAULICS #2
If the IN port of the pump is flooded, and is not sucking air, the hyd system should self bleed with operating all valves many times.
Hi JJ
Thanks a lot, will do so and keep you updated. Can it be pump failure? Or a solenoid that is stuck open or closed?
Cheers
Dom
2019 International Bucket Truck (A55973)
2019 International...
Freightliner Tender Truck - Adams Tender (A56435)
Freightliner...
2020 Ford F250 Pickup Truck (A55973)
2020 Ford F250...
2013 International WorkStar 7500 T/A Altec D3060BTR Insulated Digger Derrick Truck (A55973)
2013 International...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
