Oil & Fuel NH M135 HYDRAULICS
   / NH M135 HYDRAULICS #1
dommas
south africa
new holland
HI GUYS, I NEED SOME HELP PLEASE. I HAVE A NEW HOLLAND M135 , I FITTED NEW HYDRAULIC OIL FILTERS AND OIL , NOW I CANT GET RID OF AIR IN THE SYSTEM. PUMP MAKES A BAD HUMMING SOUND AND THE TRACTORS 3 POINT, POWERSTEERING ETC. IS NOT FUNTIONING CORRECTLY. THE FILTERS HAVE OIL IN, AND LOGIC TELLS ME THAT IT SHOULD BLEED ITSELF . CAN THE PUMP BE CAVITATING? BUT WHY NOW? ARE THERE ANY BLEEDING SCREWS THAT I DONT KNOW OF MAYBE?
THANKS
DOM
   / NH M135 HYDRAULICS #2
If the IN port of the pump is flooded, and is not sucking air, the hyd system should self bleed with operating all valves many times.
Hi JJ
Thanks a lot, will do so and keep you updated. Can it be pump failure? Or a solenoid that is stuck open or closed?
Cheers
Dom
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2013 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2013 JACK COUNTY...
CAT Skid Steer (A50322)
CAT Skid Steer...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
