Oil & Fuel NH hyd. oil vs. IH Hy-Tran
   / NH hyd. oil vs. IH Hy-Tran #1
Dave1953
Claremont, NC
5000 Ford, 2019 New Holland Boomer 55 Cab, 935GBH BH
I recently purchased a new TC34DA. I always run the Mfgs. tranny/hyd. oil in all the different tractors I have. The IH Case equivelent of the model I have would recomend Hy-Tran Ultra and since the 2 tractors are the same it would make sense to me that Hy-Tran would suffice in my NH. I have about 30 gal. of Hy-tran in the shop that I intend to use in my TC34DA. I know what the dealer would tell me if I asked him if it would be ok to use the Hy-Tran. What do some of you knowledgeable people think? Thanks for answering.
Dave
   / NH hyd. oil vs. IH Hy-Tran #2
Since the Case/Farmall compacts are identical to the NHs internally, I'd use that Hytran in a heatbeat and never look back.
   / NH hyd. oil vs. IH Hy-Tran #3
I would use the Hy-Tran also.
I previously owned a Kubota 3710 GST, I asked the dealer if I could use my JD Hy Guard for transmission oil. He said no problem. I did and had no issues. I use the same Hy Guard in my JD 3720 HST and JD 5300 gear drive.
   / NH hyd. oil vs. IH Hy-Tran #4
To add to this.. I use generic UTF instead of the 134 oil CNH sells. ( I use so much it's not financially easy to get the CNH oil! )
No problems encountered on the generic UTF
soundguy
   / NH hyd. oil vs. IH Hy-Tran #5
Since the merger of the two companies NH does offer the two oils, their original blend and the Case-IH ultra hytran. The Case oil is a bit thinner and absorbs a greater amount of moisture then the original NH oil which is good for us here in the north with the changing temperatures.
   / NH hyd. oil vs. IH Hy-Tran #6
They are not the same.
   / NH hyd. oil vs. IH Hy-Tran #7
NH markets two grades, one is the same!
   / NH hyd. oil vs. IH Hy-Tran #8
Do you mean that NH200A is the same product as HyTran Ultra? Just wondering. I hope you guys get better pricing on the CIH version than we do in the NH package.
Portable Restroom (A54865)
Portable Restroom...
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
5' ROLLING LADDER (A52708)
5' ROLLING LADDER...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
