Oil & Fuel NH hyd. oil vs. IH Hy-Tran
   / NH hyd. oil vs. IH Hy-Tran #1
Dave1953
Claremont, NC
5000 Ford, 2019 New Holland Boomer 55 Cab, 935GBH BH
I recently purchased a new TC34DA. I always run the Mfgs. tranny/hyd. oil in all the different tractors I have. The IH Case equivelent of the model I have would recomend Hy-Tran Ultra and since the 2 tractors are the same it would make sense to me that Hy-Tran would suffice in my NH. I have about 30 gal. of Hy-tran in the shop that I intend to use in my TC34DA. I know what the dealer would tell me if I asked him if it would be ok to use the Hy-Tran. What do some of you knowledgeable people think? Thanks for answering.
Dave
   / NH hyd. oil vs. IH Hy-Tran #2
Since the Case/Farmall compacts are identical to the NHs internally, I'd use that Hytran in a heatbeat and never look back.
   / NH hyd. oil vs. IH Hy-Tran #3
I would use the Hy-Tran also.
I previously owned a Kubota 3710 GST, I asked the dealer if I could use my JD Hy Guard for transmission oil. He said no problem. I did and had no issues. I use the same Hy Guard in my JD 3720 HST and JD 5300 gear drive.
   / NH hyd. oil vs. IH Hy-Tran #4
To add to this.. I use generic UTF instead of the 134 oil CNH sells. ( I use so much it's not financially easy to get the CNH oil! )
No problems encountered on the generic UTF
soundguy
   / NH hyd. oil vs. IH Hy-Tran #5
Since the merger of the two companies NH does offer the two oils, their original blend and the Case-IH ultra hytran. The Case oil is a bit thinner and absorbs a greater amount of moisture then the original NH oil which is good for us here in the north with the changing temperatures.
   / NH hyd. oil vs. IH Hy-Tran #6
They are not the same.
   / NH hyd. oil vs. IH Hy-Tran #7
NH markets two grades, one is the same!
   / NH hyd. oil vs. IH Hy-Tran #8
Do you mean that NH200A is the same product as HyTran Ultra? Just wondering. I hope you guys get better pricing on the CIH version than we do in the NH package.
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2237 (A58376)
2237 (A58376)
1995 Kenworth (A57148)
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
