NH and mower selection
   / NH and mower selection #1
mathey
Platinum Member
MD
NH TC33D
I'm considering the purchase of a NH in the TC24-25-29-31-33-34-35 range, I'd like it to be able to run a 72" mmm, and also possibly a 72" rotary.
The specs on the 72" 951b rotary only say that it will work on a Cat 1, but no specific models are listed...
it appears that the 72" 914a mmm will only fit the 29 and 33 models (what about older models?) my FIL has a TC25 with the 72" 914a and it runs fine.
i understand the weight issues with having a bigger mower hanging off a smaller tractor, but where is the fine line here? Since my budget won't allow a new purchase, i'm looking at used, and therefore also the smaller models are closer to the amount i can spend
can someone enlighten me? :eek:
   / NH and mower selection #2
NH says if you want 72" mmm you need class II boomers. I've seen the class I also a with 72" mmm on but don't know how they mount them. 72" rotary cutter IMO needs the class III Boomer. I have a 60" rc and the front of the tractor feels a little lite w/out the fel on. Greg
   / NH and mower selection #3
Sounds like Greg has it about right. The 6' bushhog may be a little big behind the class II tractor (TC 34 and below). I have a Class III tractor and it seems a little large at times. You might consider a class II tractor and slightly smaller bushhog. Remember that you can't get a MMM ans supersteer at the same time. I have SS and would rather have the MMM.
   / NH and mower selection #4
I have an 01 TC33 (current version would be the 34) with a 72" MMM (914a) that ive had for about a week now. (210 hrs on it)
No brush hog yet but if i got one id be looking at 5' (60") version.
ive cut about an acer of "lawn" with it so far and have to reclame the other acer or so i plan on having as lawn (this weekends project)
btw it does take quite a bit of power to run that 72" MMM
   / NH and mower selection #5
Hi,
I have a TC34DA w/72MMM w/rear discharge. You will need a 2000 RPM Mid PTO to run it. The 34DA has HST and Mid PTO standard, but other Class2 the PTO is a option...Bob
   / NH and mower selection #6
Andy, I have MMM and SS on a class II, can't speak about class III compatability with MMM and SS. Greg
After further review -we borrowed my FIL's TC25 with the 72" 914 MMM- it just mows too short for my wife's liking in the horse pastures. max mowing height is about 4-4.5 inches and she wants it 5-6 tall minimum.
So then I was thinking about a 72" RFM...then I went over to an area that hadn't been mowed in a while, grass was a foot tall in some spots - the finish mower just isn't designed to handle tall grass without multiple passes, eliminating the time savings of having a wide mower.
So now I'm back to a rotary mower...
the NH specs for the 72" 951B (light duty model?) say it will fit a Cat 1 tractor, weighs 642 lbs, has a 40hp gearbox rating, and fits a category IV driveline(?)
the NH specs for the 72" 953B (medium duty model?) say it will fit a Cat 1 or 2 tractor, weighs 785 lbs, has a 40hp gearbox rating, and fits a category III driveline(?)
considering I'm mostly mowing grass and 90% of the time it's of a reasonable height, wouldn't one of these mowers work fine? Is it simply the weight of the mower or is the TC33D (27hp @ PTO) not enough to run these?
   / NH and mower selection #8
I used a 5' mower on a NH 1920.. but it would pull a 6' mower fine.. I tried a howse 6' on it that my stepfather had.
Get 30pto hp , I would say for the 6' hog.. I guess that puts you with a 33-34-35
Soundguy
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A51247)
2016 WITZCO RG-35...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
Ryobi Weedeater (A51573)
Ryobi Weedeater...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
