NH 7108 loader noise at Joystick valve
   / NH 7108 loader noise at Joystick valve #1
digdug1
Austin, Texas
Kubota L3240
Hi, I am new to the forum and really appreciate all the good info shared here! I recently purchased a used Ford/NH 1720 with 7108 loader. The tractor and loader work great. The only problem is when lowering the bucket the hydraulics make a loud high pitch squeeling noise at the joystick valve. It only does it when lowering the bucket. Still does it when the machine is warm. It seems like it works the tractor more to lower a load than it does to raise a load which doesnt make sense to me? Also, the loader seems weak when pushing down (cant lift front tires off the ground). Any help would be great!:)
Thanks!
Anyone have any ideas?:eek:
   / NH 7108 loader noise at Joystick valve #3
It doesn't take much to make a squeal. There is probably something in the valve causing vibration. Sometimes even rigid hydraulic lines that are not mounted in rubber may vibrate and make a squealing sound. Try lifting the FEL and then shut off the engine. With the engine off, lower the FEL and listen for the squeal. If it squeals then, you know there is no relief valve lifting. If not, you've at least isolated the problem a little.
Many loaders can't lift the tractors with the lift arms only. Place your bucket flat on the ground and use the bucket curl-down to see if the front tires lift. I'm not sure how much curl power the 7108 has, but normally the curl function has more power than the lift arms.
Thanks Jinman, I did as you say and lowered the bucket without the tractor running and it still makes the noise (not quite as loud). I assume that I am not hurting anything?
   / NH 7108 loader noise at Joystick valve #5
I have a similar problem with a Ford 1920 and 7108 loader. I know that if slowly lower the loader it does not squeal.
Same thing here! I can lower it slowly and it does not squeal.
1985 Suzuki Shaft230 Quad Runner (A59814)
1985 Suzuki...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
