NH 469 haybine
   / NH 469 haybine #1
nckennedy
Camillus, NY, USA
JD 5425
HI Folks,
Purchased an old NH 469 this past winter and hope to cut 10 acres of hay with it.
It makes a strange noise when running as if a clutch is slipping. Is that noise normal?
Have not tried it cutting with it yet?
Craig
   / NH 469 haybine #2
There can be a lot of strange noises coming out of a 469 or 479. Try narrowing it down: once per reel rotation, a blam every once in a while, a rapping noise timed with the wobble box, in the driveline, a sizzling noise when you shut down the pto, a flapping noise from one of the rolls, or a clicking noise from the chains ? How about a phone video of the machine and the noise at its apparent location.
   / NH 469 haybine #3
HI Folks,
Craig
Not sure about your noise but I have a 488 model, and it works great. I did replace all the guards and lots of cutter teeth as well as changing out the gear oil when I bought it. DSCN1985.JPG
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2000 Mack CH13 (A56435)
2000 Mack CH13...
2009 Ford F-150 (A56858)
2009 Ford F-150...
