NH 269 baler plunger removal?
   / NH 269 baler plunger removal? #1
bjr
Eastern WA
Jinma JM354
The parts book shows a pin going thru the plunger and thru a arm that connected to the gear box arm. Is this pin to be removed to remove the plunger? If so, do you drive it out thru a hole in the hay camber? I'm just not familiar with the removal steps and the owner manual doesn't address plunger removal. What do I do to get the plunger out? Thanks. bjr
   / NH 269 baler plunger removal? #2
Take the plunger and connecting rod out the back together. Two bolts connect the crank arm bearing housing to the connecting rod. Block the hay dogs out of the chamber, remove any wedges present, and remove the thrower, if equipped.
   / NH 269 baler plunger removal? #3
I'll add to what Rick stated that I always loosen the 2 springs on the rear of baler that control the hay tension and block hay tensioner up out of the way of PH
   / NH 269 baler plunger removal? #4
That about covers it, should slide right out.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
378811 (A51573)
378811 (A51573)
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51246)
CATERPILLAR V50B...
