NH 1720 Wants to tip over
   / NH 1720 Wants to tip over #1
VetRick
New Holland 1720
NH 1720 tips dangerously to the right even on level ground. It is a 4WD with a FEL. Problem started a few months back when operating on wet ground while moving hay rounds but has gotten worse to the point that left rear wheel has come off the ground. Now it happens even when there is no load on the loader. Any thoughts on where the problem could be? Wheel, differential, axle? Front axle is on a center pivot pin and there is no discernable leakage or disconnected parts. Thanks! Any help is welcome.
   / NH 1720 Wants to tip over #2
Astounding! Unnaturally twisted. Need pics.
   / NH 1720 Wants to tip over #5
Seeing tractor design I have a really hard time understanding your problem.... Maybe tire pressure is abou only thing other than bad load balance in FEL...
Might try wheel spacers to widen the rear track for more stability...
   / NH 1720 Wants to tip over #6
Check to see if you have cracked frame as a result of picking up the hay rounds.
Hose Reel (A53424)
Hose Reel (A53424)
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
Sheets of 12' Tin (A53316)
Sheets of 12' Tin...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
