NH 1715 clutch stuck to flywheel
   / NH 1715 clutch stuck to flywheel #1
JGS&CWS
New Holland 1715
NH 1715 clutch stuck to flywheel. Is there anything I can do to free up the clutch, or will it require a trip to the shop.
   / NH 1715 clutch stuck to flywheel #2
Bang it into a tree in a gear like number 3. It'll free up the clutch (make sure you press the clutch as you bang into the tree!)
Won’t go into gear, so can’t move it. Tree probably not an option.
   / NH 1715 clutch stuck to flywheel #4
Rock it back and forth to get it into gear. Easiest way I ever got something (old land rover) into gear was just start engine and start drifting the truck and then slide it into a gear as it's moving. Worked every time.
   / NH 1715 clutch stuck to flywheel #5
If brakes work, start the tractor in gear and while holding clutch in, push hard on the brakes. That usually will free it up. Make sure you have plenty of room so you don’t run over anything.
   / NH 1715 clutch stuck to flywheel #6
Stout tree method is best. Tractor brakes are iffy. Next time when you park it, put a block of wood between the pedal and the mount. Many tractors come with a pedal hook to keep the clutch depressed when parked so the plate don't rust to the flywheel.
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2003 International 4200 24FT Box Truck (A51692)
2003 International...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
2003 Ford F-250 Knapheide Service Truck (A51692)
2003 Ford F-250...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
