NH 1715 clutch stuck to flywheel
   / NH 1715 clutch stuck to flywheel #1
JGS&CWS
New Holland 1715
NH 1715 clutch stuck to flywheel. Is there anything I can do to free up the clutch, or will it require a trip to the shop.
   / NH 1715 clutch stuck to flywheel #2
Bang it into a tree in a gear like number 3. It'll free up the clutch (make sure you press the clutch as you bang into the tree!)
Won’t go into gear, so can’t move it. Tree probably not an option.
   / NH 1715 clutch stuck to flywheel #4
Rock it back and forth to get it into gear. Easiest way I ever got something (old land rover) into gear was just start engine and start drifting the truck and then slide it into a gear as it's moving. Worked every time.
   / NH 1715 clutch stuck to flywheel #5
If brakes work, start the tractor in gear and while holding clutch in, push hard on the brakes. That usually will free it up. Make sure you have plenty of room so you don’t run over anything.
   / NH 1715 clutch stuck to flywheel #6
Stout tree method is best. Tractor brakes are iffy. Next time when you park it, put a block of wood between the pedal and the mount. Many tractors come with a pedal hook to keep the clutch depressed when parked so the plate don't rust to the flywheel.
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
ATTENTION PLEASE READ (A50123)
ATTENTION PLEASE...
2011 Kia Forte Sedan (A51694)
2011 Kia Forte...
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
2015 Ford Explorer AWD SUV (A51694)
2015 Ford Explorer...
